Mercruiser 7.4 Carburetor 9777s needs repair kit
shellone
A 7.4 engine serial OF079329 from I believe 1994, probably with the original stock 4 barrel carburetor. The carb has number 9777s 0983 carved in the front. Is this number enough to identify what make and model it is so I can start searching for a repair kit ?
You have a Weber AFB (also Carter AFB) model 9777s, same as Edelbrock 1410
Rebuild kit numbers are 809064 old and 8M0120193 new. Either number will bring up the kit
shellone
THANK YOU VERY MUCH !!
shellone
Thank you for the hint, unfortunately I am presently in Europe so I will need to wait for shipment from China ! Would a kit for Edelbrock 1410 fit ?
I think yes but might be worth a email to edlebrock to confirm.
Ayuh,...... It's the same carb, so yes, it uses the same kit, which is much cheaper than the kit badged as Merc,.....
