Mercruiser 888 - Ford 302 w\ Alpha1 R running temp
RCAnderson
Hello All,
This is my first post here, I've been looking around for the past week, coincidendally since I bought my first boat in many years. I did a compression test and cooling system leakdown test (fwc) before buying the boat and while the compression was not through the roof, it wasn't too bad either. The coolant system was charged to 15 psi, and lost about 2 psi in the 20 mins or so that it took me to do the compression test. I think most of that 2 psi came out the pressure gauge connection to the heat exchanger. No water in the oil, other than a bit of condensation. Put the muffs on the leg and ran the engine, temperature climbed up to the red zone on the boat's temp gauge (this is in the sellers driveway, I didn't have my infared thermometer with me). So I'm thinking the raw water impeller needs to be changed, not that big a deal. So I bought the boat.
First thing I do is drop the lower unit and I can see right away that the engine must have been run with no water through the outdrive, as the plastic water tube is melted, when I took off the upper water pump housing, the impeller was stiff and chipped in places, but not melted, and the upper housing was melted directly below the shaft exit, where there is a groove in the housing. Intake screen is not clogged at all. I blew compressed air up the water tube (with the other end of the hose off the heat exchanger) and it is not blocked. So I get a new upper water pump housing and impeller kit, change all the parts, and put it back together. Hook up the muffs and run the engine, and the temp climbs up to 180 and sits there. This is measured with the infared thermometer, and the dash gauge is reading very close to the red zone. So I'm now thinking that someone put a 180 automotive thermostat in the engine. Pull off the thermostat housing, and there is no thermostat in there. Wonderful. Now I'm thinking I have a much more serious problem. Pull off the heat exchanger end caps, and it's not totally clogged, but not that great either. So I remove the heat exchanger, as well as the exhaust risers. The risers look absolutely perfect, no corrosion or blockage anywhere. So I get the heat exchanger hot-tanked and pressure tested at the rad shop, and re-install everything, including a 165 thermostat. Run the engine on the muffs again, thermostat opens at 165 exactly, engine temp still goes to 180. So I remove the exhaust manifold endcaps to have a look, other than being pretty black, they look fine. Remove engine circulating pump, thinking it may be an automotive version and the impeller corroded, but no, it's the marine version, with bronze impeller and it looks to be in fine shape. I blew compressed air through the block from the ports for the water pump, seemed like good flow through the block. So I put everything back together, filled up (again) with fresh 50\50 mix coolant, and ran it again. 180 again. It doesn't matter if the engine is idling or running at about 2500 rpm, it stays at 180. Obviously, this is unloaded. The temp at the thermostat housing is 180, at both manifolds 200-210, at risers 120, at top side of heat exchanger 180, at bottom of heat exchanger 120 (where the engine circ. pump pickup hose is). So it seems to me I have 120 deg water going into the engine block, heating up to 180 by the time it gets back to the heat exchanger, and that the heat exchanger is doing it's job, and that I have enough raw water getting to the heat exchanger in order for that to happen. There is a good amount of water coming out of the exhaust port in the propellor as well.
So I put the boat in the water, curious to see if the temp stayed at 180 loaded or not. Got the boat off the trailer, and stalled repeatedly trying to get into reverse. I had tested the shift system on land, and it seemed to work fine, but once in the water not so much. So now I am replacing the lower shift cable, all bellows (even though they don't seem bad at all, I'm in there anyway). That should fix that problem, but I still haven't tested the engine temperature under load. 180 seems high to me, but maybe not, as automotive engines idle at that temp, although granted most have a 180 or 190 thermostat. I'm thinking that with a 7psi cap on the heat exchanger, the coolant shouldn't boil until about 220 or 230, and maybe I'll be okay ?
Again, I have checked all hoses and ports for blockage, hot tanked the heat exchanger, replaced the raw water pump housing and impeller, checked the engine circulating pump. Nothing seems to be wrong with any of it. The heat exchanger is 4" diameter, which I see is about the right size for a ford 302. A 5" heat exchanger would provide more cooling, and perhaps I am going to have to look at replacing mine with a 5" ?
Any thoughts, suggestions or ideas would be much appreciated.
Thanks,
Ryan
RCAnderson
Re: Mercruiser 888 - Ford 302 w\ Alpha1 R running temp
So it turns out that the root cause of the shifter cable binding was a leaking shift shaft seal, which I will replace today. Sort of surprised that they don't come with the shift cable kit.
No thoughts from anyone on the engine temp ?
Thanks
Ryan
haulnazz15
My 351W runs at 140-150 all day long per the engine temp guage, but it's raw water cooled. I think your 302 should be running pretty close to 160 if that's what thermostat you have in there.
RCAnderson
I thought so too, with all the cooling system checks I did, but it blows right past the 160 thermostat and runs at 180, all with no load on it. Is 180 too hot ?
Ryan
haulnazz15
Have you tried running without the thermostat in, just to check that. Or take the thermostat and put it in some water on the stove and see what temp the thermostat opens up at?
RCAnderson
Yes, I did try without the thermostat. In fact, I thought for sure at first that there was a 180 deg thermostat installed, so I pulled the housing off, and there was no thermostat installed at all. So then I got my heat exchanger hot tanked and so on and so forth. I re-installed all that, along with a 165 deg thermostat, and tried again. The heat exchanger then stayed cold until the thermostat housing got up to 165, then the thermostat opened and the heat exchanger temp shot up to match the thermostat housing, and the engine temp continued to climb up to 180. So the thermostat is working. Even so, I removed the thermostat again, tried again, thinking that maybe the thermostat wasn't opening enough, but got the same temperature results. So I'm still stumped on the cooling issue, but perhaps I'm overthinking, and 180 is normal for a fresh water cooled 302 with no load ?
I am almost finished putting the outdrive back on, and have discovered that you absolutely cannot get at the hose clamp on the u-joint bellows if you put the bellows on the gimbal housing first. So I have to take the bellhousing off again and put the u joint bellows on the bellhousing first, just like you are supposed to do. Oh well, learning experience.
I have always owned boats with Volvo outdrives before this (much older ones, 140's) and I have to say that they were much easier to work on as far as bellows and connections goes.
Thanks
Ryan
Ayuh,.... 180? is fine if it stays there,... WITH a load...
Fordiesel69
Was the HX rodded out properly? Hot tanking it will not do much if certain deposits are present. If running in fresh water, you can remove the closed cooling.
RCAnderson
I agree 180 is okay, if it stays there, but what are the chances do you think ?
Yes, the heat exchanger was fully cleaned and pressure tested.
Although I can't imagine this to be the trouble, does anyone know what the wear limits are for the engine circ. pump impeller ? It looked perfect to me, bronze impeller and all, but I'm thinking that if I don't have enough flow through the block and the HX, this could be the problem. I'm contemplating just getting a cheap auto water pump and trying it out, as I'm out of ideas.
This boat will be used almost exclusively in the salt, with maybe the odd trip to some of the larger lakes on this rock.
Thanks
Ryan
