Mercruiser Alpha one Gen 2 water temp question
dmoccia
Cruising for some comments: My boat has three 4 components associated with water temperature: temp gauge, temp sender, temp. switch and thermostat. While running under high load (4000-4500 rpm) temp gauge reads 175 deg consistently. At the same time, I get intermittent alarms which I had suspected were due to engine temperature. I took out the sender and the switch and tested both. For the sender, the manual shows a table that has resistance readings that should correspond to temperatures:. at 140deg F-121to147 ohms, 194 deg F- 47-55 ohms, and at 212deg F-36-41 ohms. At 212 deg F, the lowest resistance reading was 55 ohms. The manual says to replace it if any of the readings are outside the ranges shown in the table, so I conclude (sort of) that I need a new sender. I also checked the temp switch (part 48952) and it appears to be ok. The switch is supposed to close at 190-200 deg F. It closed at a little higher than 200, more like 210 but that could have been due to my water bath setup causing some inaccuracies. I haven't checked the thermostat yet. Would like to hear from anyone that knows about this system, particularly whether or not what I have described would cause me to get alarms while running.
You can also get the alarm from low drive lube bottle and low oil pressure . you can diconnect these one by one and see what makes alarm go away. like temp oil has a sender that works the gauge via ohm signal to gauge and has separate switch at like 4 or 7 psi that trips switch.
verify temp with IR gun or calibrated hand on thermostat housing , oil pressure with mechanical gauge to rule out actual issue vs false alarm.
dmoccia
Thanks. I will try.
What motor, serial number is best?
What kind of alarm, single beep, constant beep, double beep?
The Temp sender for the gauge will not cause an alarm
