Mercruiser Big Block Gen 5 raw water pump pulley
04fxdwgi
Looking for a good used, single groove, V-belt pulley for a '92 Bravo (Gen 5) big block raw water pump to put on rebuilt spare pump assembly I have.
Haven't found a used one and new ones are too pricey for a "spare".. For what a new one costs, I'll swap out the one I have, when the time comes, if I have to.
If anyone has one lying around they want to part with (for a price), let me know.
Thanx
Can you use an automotive one from a 454 Chevy? It would be cheaper, if you can cross the part number over.
Think this is in the rule 8 area
But the part number 818365T and by my measurements diameter is 5 3/8 , V grove is 1/2 , shaft diameter is about 3/4
04fxdwgi
Yup, just saw that rule #8. Knew one couldn't sell, but didn't know one couldn't beg..... And yes, AllDodge, that is the correct part number.
Mods, please delete original post.
Thanx
If the Mods change it to does anyone know where I can find a used one, then I think you will be fine
