Mercruiser bogs and dies
sealyons
1985 Merc MR 200 runs ok in neutral and underway when slow, but once given some throttle it bogs down & dies. It will restart and stay running if feathering the trottle and will ultimjately idle 'normal' again after a short while. I am able to rev high in neutral and it will happen as well. Replaced fuel filter, plug wires and cleaned cap & rotor. Fuel is new this year and has stabilizer in it. Carb is a 4bbl rochester quadrajet. Had fuel issues last year and changed tank. I would appreciate any suggestions!
wooly
Re: Mercruiser bogs and dies
I had a similar problem, cutting out when accelerating, try changing the coil, I changed from a merc to a bosch and everything is now good.
sealyons
I did replace the coil, and still same symptoms. I plan on hooking up an external fuel tank to see if it is delivery problem between the tank and fuel pump next.
Common problem....... it may be time to rebuild the accelerator pump in the carb....... be sure to use a marine grade repair kit.
sealyons
I also forgot to mention that the tach shows a very high RPM 4k when first started and then back's down to the norma 1500 to 2k i have it warming up at. The engine is not running that fast, tach is just registering high initially. I plan on running from external tank to verify that it is not a leak on the tank/ water separator side of the system. Also going to change the plugs. I had a similar problem years ago that was fixed with a new coil, the new coil I put on this year didn't fix the problem.
shopboy
I had the same probem. Mine was carb related BUT
I've read that if your tach is malfunctioning it can ground out the coil causing running issues.
The tach wire is connected to the negative pole on the coil I believe. You can test this by removing the wire and running
6meter
Previous tank issues could mean the carb is dirty inside. Time for a rebuild.
sealyons
Mystery solved....somewhat. Found the fuel filter in the carb almost completely plugged it's amazing it ran at all. Had it out for over an hour yesterday and it ran well though I never opened it up completely, I had it at higher RPM's than I had earlier when I experienced the issues. Plan on getting it out in the next day or so to put it through the paces. Tach is still erratic, shows higher than engine sounds and then comes back down and repeats with no regularity. Also shows about 1k whan the key is off...
shopboy
Maybe try to find another tach to borrow and install and see if the problem still exists..
If so, you'll need to find the problem in your wiring... Check all the connections etc...
I think its normal for some tachs to stay above 0 when turned off, but the fluctuation while running is definitely an issue.
BIGALF
I suggest you also check the filter in the fuel take. I had that problem and found that the take filter was also clogged.
