Mercruiser Drive Reservoir location
Eric.G
I just replaced a 96 350 with a Vortec 350. Everything went fine, but I cant figure what to do with the Drive Reservoir. The old bracket mounted on the last two bolts of the intake manifold. Of course the Vortec manifolds are different. Where does the bottle mount on Vortec engines. I've see a couple of different brackets on line, but cant visualize where they would go. Ive seen one that looks like it would mount on the back of the port head, but of course the coil is there
Thanks
Eric
TilliamWe
Banned
Re: Mercruiser Drive Reservoir location
My 1997 Bravo was mounted on the starboard front corner of the engine. Can't remember what the bracket actually attached to, though. Maybe the head? Here's a picture of it, maybe that will help you decide which bracket?
Eric.G
On mine (all factory) both the old setup and the new setup (merc factory partially dressed MAG+ engine) has the fuel water separator there. Hangs between one bolt on the manifold and one bolt on the head.
THANKS for the Pic. At least I know what application that particular style bracket is for.
Eric
TilliamWe
Banned
Yeah, my fuel/water separator is underneath the drive reservoir. Maybe that's a "Bravo" thing? Merc does change things from time to time, though.
Eric.G
Any more input??
The wiring harness for the new engine still has the lead for the drive reservoir in the rear port area of the engine
Thanks
Eric
Any more input??
Thanks
Eric
Ayuh,... Just hang it wherever the wire from the harness will reach...
