Mercruiser Engine, OMC outdrive; exhaust elbow issue
Mystic Dragon
I replaced my OMC 3.0 L with a Mercruiser 2.5L. I had to kuse the old bellhousing and coupler and now I am faced with yet another problem. The exhaust elbow is 25 degrees clockwise of the riser on the outdrive.
Does anyone know if they make an adapter for such a change, or do I have to replace the exhaust manifold?
Scaaty
Re: Mercruiser Engine, OMC outdrive; exhaust elbow issue
Probably be easier and cheaper in the long run to update the Manifold, as they need periodic replacing anyway...
Use the 1 off the 3.0l.............
Mystic Dragon
Thanks guys. I am going to research replacing it. I was hoping that someone made an adapter since the motor is back in the boat now. Oh well, youins gots to dooz whatchya gots to dooz! LOL
Thanks again. If any other ideas come to mind, please let me know. This has been one heck of a weekend project. :/
Mystic Dragon
Well, I have purchased an adapter that may align the two without replacing the exhaust and riser. It is a 70 dollar gamble versus a 450 dollar replacement.
We'll see how it goes this week.
Mystic Dragon
OK, I got the adapter and it doesn't look like it will work without some hefty modifying. I am looking for a manifold and am not sure which one will fit.
Recap - I have a Mercruiser 2.5 L that I need to adapt to an OMC outdrive exhaust. Will the 3.0 L OMC mainfold PN 984054 work on the Mercruiser 120? Or do I need the log style that is for a OMC 2.5 L?
I hope someone sees this thread. Help Admirals! LOL
You Need the Same 1 that was on the Original motor.......
Mystic Dragon
Thanks Bondo! I will be ordering it tomorrow. I'll let you know how things go.
