mercruiser gear lube?
mattie_k
Do I have to use the mercruiser gear lube in my alpha one (gen 2) or can I just pick up something like a premium synthetic gear lube from the auto parts store? The problem is that the nearest marina is 3 hours away.
Capt Ralph
Re: mercruiser gear lube?
I read somewhere on here that 80w-90 gear lube works just as well. I used Valvoline 80w-90 in my Alpha I gen2<br /><br />-CR
I use Mobil 1 75W-90 Syn-oil........
summerwind1991
Is there an adequate substitute for Mercruiser Gear Lube part no. 92-802854A 1 @%$10.95 quart? Synthetic Oil? Which weight?
The Alpha I Gen II Drives from Mercruiser list out at $5300. Sure you can buy rebuilts, and cheaper imitations, but don't you think any of them would be worth 15 bucks a year to put the correct gear lube in?
Sea Ducer
Hello ,<br /> Just a new cadet here but I did work on a lifetime marine mechanics house & he showed me the graphs on the different lubes & I will use nothing but the Merc QuickSilver in my units.<br /> Of course graphs can be manipulated to sway one way or another but for the little cost difference it aint worth the repairs!!
rodbolt
I dont know anything about graphs, I hate marketing and I am no where near as technoligically sophisticated as DonS nor do I have half his knowledge.<br /> I have done this marine repair gig on and off(break for the USN) for about 30 years.<br /> the merc HP gear lube for mercs V6 and all mercruisers is about as good as it gets.<br /> I also work mostly as an independant contractor and get paid nothing for parts or materiels used so I only use what I think is the best for the application.<br /> it aint my shop nor my money however it is my reputation on the line.
Lou C
My mechanic uses the Merc HP gear lube in my old Cobra drive because he feels it is the best there is, he could just as easily use the OMC/Bomb stuff since he sells their stuff too, it is able to lube the drive even if you have water intrusion, which is the main advantage over a non marine lube.
