Mercruiser Manifolds - Fit Question
pachanga27
My boat- 1989 Sea Ray Pachanga 27 - Twin Mercruiser 350 Magnums -
Question - I bought two sets of used Mercruiser manifolds and elbows to replace my manifolds and risers which were very corroded.
The manifolds came off a 1993 boat that was said to be Mercruiser 350s but when I looked up the part number stamped on the manifold - the description says 5.0/5.7 (305 and 350) and I was skeptical about using them. In the end I bought two sets new from a company (via iboats) as I needed the 6 inch riser extensions anyway and to make sure I had all the correct gaskets and bolts. In the end - the new sets fit perfect and I have these two sets of Mercruiser manifolds and elbows which are in very good shape - but I don't need. I want to sell them but I want to make sure I advertise correctly which the motors they will fit. Using the numbers cast into the manifold . 860246-C - besides going by Google - is there a definitive way to say ..these manifolds fit... which motors and which years?
They would actually fit the cylinder head of any 1st and 2rd generation small block chevy, including Vortec heads
Ayuh,.... SBCs, the 305, 'n 350 are exactly same, dimensionally, externally,....
Their exhaust manifolds are the same parts,....
