Mercruiser out drive swap
putback
Will a 1985 3.0 Alpha 1 out drive bolt up to a 1984 3.0 140MR ? Both in glass starcrafts, side by side they look the same except for the rear decal. The '85 says Alpha 1' the '84 has a big #4.
Ayuh,.... Direct swaps, Plug, 'n Play swap, No problem,.....
putback
Thanks, Both work fine The '84 needs strip & paint. The '85 shines like new. I can swap now and redo the '84 next winter.
