Mercruiser Power Steering Question
ewpvic
I am looking at an engine swap (complete). Mercruiser 5.0 2000 for a 2002 5.0. The only difference is that mine has power steering and the other one doesn't.
It appears that I would just need to add the bracket that facilitates the reservoir/pump and motor/pulley.
Would there be ANY reason that where the bracket mounts is different between these two blocks?
Thanks
Thanks
Ayuh,.... No problem, none of those holes have moved since I think 1979,....
