Mercruiser repair shop reccomendations
maxum1800
I recently purchased my 94 maxum 1800 and had a problem finding a lower unit lube leak which all you guys were able to help me find. Now after reading many posts I'm in need of a highly recommended repair shop as I think I've decided to have the outdrive removed,input seal replaced and while its off I want all the bellows,cables,trim switches,any other parts replaced and adjusted properly. Price is not my main concern as much as a clean and proper install off all parts just like the boat was made new. Properly routing cables and wiring and adjusting it all . I would like to hear from someone that may have first hand experience with a local shop that they would be able to recommend. I'm located in Scotia,N.Y. zip code 12302 Thanks Tom I usually do things myself as it seems when I do try to have someone do something for me,I have ended up not being pleased with the work. The last time was with a pool liner replament and I hired a large pool company and when the pool was half full the liner pulled out of the top rim and was hanging done 5 inches. I called and they said no problem they will need to come over and heat and stretch my new liner and put it in place. I didn't want them to stretch anything as I saw excess liner bunched on the bottom . They ended up coming over when they thought I wasn't home and was setting up a heatgun and I sent them packing. I drained the pool and spent the whole day adjusting the liner and refilled it ? I don't want to go thru that with my boat!
jerryjerry05
Re: Mercruiser repair shop reccomendations
Google Mercury Marine and look for Mercruiser dealers.They will list all certified dealers in your area.
Just because they are certified don't mean they hire competent mechanics though.They only need 1 certified mechanic to be an authorized repair center.
They will list the dealers in your area.Go visit them and ask questions about what you want done.Jerry
