Mercruiser serial number help
Walker600
Can anyone clarify exactly the model or year for a mercruiser 3.0 S/N
0w043698, with relavance to orderings parts,
It seems there were revisions in 97-99 and 2000-2003.
I really don't want to order expensive engine parts and find there for the wrong engine.
any help greatly appreciated.
Re: Mercruiser serial number help
Ayuh,... Merc.s aren't sold, nor serviced by Years...
Order your parts by Serial #s, 'n you'll Never have a problem....
You can call mercruiser up if you have your serial number and they can give you the information you need. Here is the number. I think select option 4 in the automated menu 405-743-6566
Fun Times
Your engine serial number is going to be 0W043698, Model number 4111021N2 MERCRUISER 3.0L WOPS 3.0L ALPHA with a alpha drive, 2.00:1 gear ratio.
The Engine Manufacture Date was on 07/16/2004.
The service manual from mercruiser that you should want to buy from a mercruiser dealer for your engine is going to be part number 90-8613291, Otherwise known as mercruiser service manual #26 GM 4 CYL 181 CID.
And here is a link to your engine parts, that falls within your engine serial number.;)
http://www.mercruiserparts.com/selectDocs.asp?doc_nbr=804862+99
Walker600
Thanks for the great responce. Very Much Appreciated :D
