Mercruiser Steering hose choice?
harveycrew
I have the mercruiser 5.7L/ 260hp 350cid OF269544. I need to replace the power steering hose-high pressure one. The numbers that show up from mercruiser are 32-90494 (s/n OF114689 & below), 32-80622216 (s/n OF114690 & above) and 32-80622236 (s/n OF114690 & above-jackshaft models). Questions, what is a jackshaft model and do I need 32-80622216? Thanks for the help. :confused:
Re: Mercruiser Steering hose choice?
the jack shaft motor is mounted at mid-ship... the hose will be Much Longer than a standard engine/outdrive...... if the back of your engine is no more than 18" to 24" from the stern... it's a standard system....
harveycrew
Thanks. That should save about $30.00. I appreciate the help. ;)
