MErcruiser "top cap" or top cover assy question
Mbrgr1
My top cap with the cracked hook eyelet is part number 55758, and I bought a 76098 that was supposed to be a replacement, but the bearing race diameter is larger on the 76098.
What to do? One is 1.782 and the other 1.937
Thanks
Bt Doctur
Re: MErcruiser "top cap" or top cover assy question
and your replacing the cap why? return it if you can ,I have flat caps that fit.
Mbrgr1
Thanks, I replaced it because the eyelet is broken, it's a twin 6cyl, and I'd like them to match, and, I'd like to hook them while trailering.
MK
Bt Doctur
I`ll check tomorrow to see it it`s still there but your hydrolics should hold the drives in trailer position
