MERCRUISER VS VOLVO-PENTA BLOCKS
LANCLJ
Anyone know if there are any differences between the Mercruiser 5.7 EFI Block and one with a Volvo-Penta 5.7 EFI serial tag ?<br /><br /> I don't think there is, but you never know ......!
Re: MERCRUISER VS VOLVO-PENTA BLOCKS
Mercruiser and Volvo Penta are two different companies.<br /><br />Volvo Penta did have a joint venture with OMC in the early '90's. Perhaps this is what you are thinking of?
LANCLJ
They are two different companies ???? NO KIDDING !!!<br /> Thanks for the reply, but C'mon, now. I just wanted to know if there was anything major that was different betweeen the blocks produced for the two companies.
Scaaty
350 GM small block ...both...bazillion made
If you're talking about the Engine Block,.......<br /><br />Robby is Right,.......<br /><br />They're All Chevies underneath.......
LANCLJ
THANKS.<br /> <br /> I picked up a 5.7 Vortec, and am going to hang onto it for "spare" parts, as long as I continue to run a small-block in the boat.<br /> Just curious about the Volvo-Penta ID tag.
rodbolt
one is painted black and the other was gray or red. does that help :) <br /> but as far as the base engine as long as both had the same EFI setup the blocks are mostly the same.
