Mercuiser 3.0 wire harness
lgrouper03
I need the male side of the cannon plug (with about 12" of wire) that plugs into the engine harness. Everything else is fine with the harness, but plug is bad. Engine serial is OF017141. Anybody have any suggestions on where to find this? I just tried ebay but could not find my configuration or I had to buy the entire instrument harness for big $. Thanks.
achris
More fish than mountain goat
Re: Mercuiser 3.0 wire harness
A complete harness is usually the only way you'll find the plug. Nobody sells just the plug..... sorry.. :(
JustJason
You can always buy yourself a couple dozen male/female spades and crimp it all, heat shrink it all, tape it all, wire tie it all.... all by yourself. Good quality spade connectors with some dielectric grease and a good crimper will work just as well if not better than the cannon plug.
Fun Times
Check in here for what you need.;)
620-08813
Hardin Marine Wiring Pigtail
MerCruiser Style Wiring Pigtail - Mercury Plug, Instrument Side 12"
Detailed Product Information
$39.99
http://www.cpperformance.com/SearchResult.aspx?CategoryID=109
I may be wrong, but I think CDI electronics carries the pigtails also. If you want to look, it's www.cdielectronics.com
Ayuh,... Or,... Find a junk boat...
