Mercury 150hp Black Max Serial Number 5204056 what year?
fcross69
Hey all I recently bought a 1980 Champion Swift with a 150 Black Max with a serial number of 5204056 I was wondering if any one has any info on this motor such as year and such I had a friend tell me its a XR-2 motor. But I would like to know what I have before I start buying parts. I would also like to know this info so I can remove the idle stabllizer and time this motor correctly and run off its mechanical timing only. Thanks any info would be greatly appreciated.Motor.jpgInside.jpgFast lol.jpg
Re: Mercury 150hp Black Max Serial Number 5204056 what year?
Check for year on maxrules website. Likely about 1980 vintage. XR2 has the smaller gearcase, if I remember correctly.
Faztbullet
1979 as it got the twin rams and 1980 has the single ram. Motor also has butterfly choke system which makes them a bear to start.
Not a Xr2 in any fashion just a stock 2.0L
Yes and its best to do this...
fcross69
This motor has a enricher valve on top carb that has a fuel line feeding into bottom of bowl no choke flaps so whats that mean?
Faztbullet
A) Someone updated motor with newer carbs to get it to start B) Midsection has a later model powerhead installed. Look on the cylinder head and get head casting number and we can tell from that. Also a nother give amay is no casting boss or area has been milled for a oil injection pump on block.
