Mercury 200xri shifter beeping
carholme
Re: Mercury 200xri shifter beeping
From Specifications Section 1A in the manual:
110 – 135 psi
(753.3 – 924.5 kPa)
Variance between cylinders should not exceed 15 psi.
Gerry
jays92
Guess i should have looked first.. Thanks Gerry
jays92
So where's the best place to get parts ?? I'm in Sanford,Fla but it seems like i will have to order parts off one of the sites i've been checking out.
Dukedog
I would recommend findin' a "good" machine shop first. Ya gotta be careful here, Do your home work. Its gotta have at least one cylinder fixed. Might as well have tha others checked or ya might be right back ta square one in short amount of time..............jmo
jays92
Gonna start taking the motor apart this weekend. Found a good machine shop.
jays92
I replaced the one piston and rings. Now the beep beep beep is still happen. I replaced the oil cap because it was broke.It seems to run fine but don't want to run it with the warning beeper going off. What should i do now. i'm missing the whole summer season of boating.
