Mercury 402 40 hp water in upper cylinder when running
Phazer230
Hi guys, I am working on a friend's old merc 402 40hp outboard and when it's running it is spewing water out around the upper spark plug, does this mean the block is cracked or is there other possible issues for this to happen ?
Likely a Leaky Water Jacket Cover Gasket and/or Warped Water Jacket Cover.
Seems to happen a lot on engines that get a little too Warm, too many times
Replace gasket as stated above.----Might as well do your friend a favor and replace water pump impeller.
Phazer230
Hi thank you very much for your reply! Does this happen to be this in the photo as some are located on the rear of the engine where the plugs are aren't they ?
OK Sticker/Decal, is just an Engine Test Run was done at the Factory. Which on this engine, was about 50 yrs ago
Phazer230
Or
So this is the water jacket area that may need attention? Thank you very much for your help !
Are the Spark Plugs there?
Here is my 84 115, getting the same repair
Phazer230
No, spark plugs are not in the area I pointed too that's why I am asking, what I pointed to might be the exhaust portion
Phazer230
This is what the 402 40 hp looks like then ?
Yep, that is the cover that is leaking if the water is coming out by the Spark Plugs. Hopefully you won't break any of the Bolts that hold it on. You will have to remove the Parts of the Cowl Support Frame(front and rear) to be able to tilt the Lower Cowl to access the bottom of the Jacket. You can see how I had to tilt it to gain Access.
Phazer230
I am having trouble locating the gasket needed part number 27-854901 quicksilver I think
Phazer230
Yeah, I saw the Philips screws in the bottom, will do, thank you
Phazer230
Gaskets came in today anyone happen to know the torque specs for the merc 402 ? 20 lbs good enough? And do you guys recommend ATV sealant on this water jacket cover gasket ? Thanks
Phazer230
I got the job completed and no more water leak, thanks everyone for the advice!
