Mercury 70 HP Identity?
triman
My neighbour has a Mercury 70HP, 3-cylinder outboard. I convinced him it's time to do an impellor change so I did a serial number check using about 8 sites where these are listed, but couldn't find it.
The serial number, recorded on the plate on the port side of the transom bracket, is
8022278A
Any advice on what year this would be?
Also would anyone be able to identify the impellor number and the complete pump rebuild kit number?
Thanx in advance.
Dukedog
Re: Mercury 70 HP Identity?
That serial number falls into tha 65hp 3 cly Aussi version range. Tha 70 hp numbers start at 8042350. A indicates Aus.
Not positive about all this. It gets kinda tricky with tha AUS numbers and horsepower/year....................
triman
Thank you Dukedog. I couldn't find an Aussie list.
