Mercury Ignition Question
TommyD11730
Guys
I would like to replace the old Mercury ignition switch on my boat.
It has 10 wires as follows:
2 Black Wires
2 Black with a Yellow trace
2 Red
2 Purple (pink?)
1 Yellow with a Black trace
1 Yellow with a Red trace.
My questions are can you use a 6 wire switch that I seem to see for sale all over place?
Does anyone have a color breakout for my switch?
Thanks!
Tommy D
Re: Mercury Ignition Question
Not sure why you have 10 wires on the switch. Black is ground, black/yellow is ign killer, purple is ign accessory, red is +12VDC; yelow/black is choke, yellow/red is starter solenoid.
TommyD11730
The switch is hardwired to the harness. Its OEM to 1988 standards. Thats a great diagram...any chance you could find mine as well?
phebus1
I had multiple wires of the same color going to my ignition switch also. They were soldered together on the terminal. When I replaced the switch, I used crimp terminals and just crimped the wires together on the lug.
SparkieBoat
that one is for a 1984 I think..should be the same as your 88
