mercury lower unit
fishmonger.33
i have a mid to late 70's merc, and am looking at buying one for cheap, it is ok to simply switch lower units on these motors? i mean does everything fit the same, it is the same hp. both 50hp 4 cly. except one has pw trim and one doesnt.
thanks
fishmonger33
gejandsons
Re: mercury lower unit
Yes the parts are interchangeable on like motors. Power trim is an option.
Fish, If you are simply planning to move the Power Trim, it is far easier to remove/reinstall the PTT brackets, rather than pull the powerhead and lower unit and switch midsections.
fishmonger.33
ok, heres my situation, i have my original motor, which i overhauled the lower unit on, but the uper shift shaft in the motor snapped becuase it rusted through, and to take apart the whole motor to get at this shaft out is alot of work i dont have time for. plus the part has been discontinued. and im interested in picking up an almost identical motor for cheap. so i want to take my overhauled lower unit, and put it on the new motor i am planing on buying (the one with the power trim) because this one i am buying needs a new water pump impeller, so i can put on my fixed up lower unit on this motor with pt, and keep my old motor and the loer end from the one im buying for parts. so i was just curious if anything would be affected by the switch of lower units
thanks again
fishmonger
If the only difference in the motors is that one has PT and the other one doesn't, then the Lower units should be identical. You will want to remove the reverse lock rod on the manual tilt model, since you will no longer need it.
fishmonger.33
thanks, will do, i am going to look at it shortly, i hope it is in better shape then mine, ive been so anxious to get out on the water this year! its driving me crazy, ans just another quick question, by hooking up a batery to the motor, can i test the pw trim?
thanks again
fishmonger
Fish, The PTT units should have seperate battery cables, from the motor.
fishmonger.33
bad news, the guy i was going to buy it off was a complete idiot, it did not have power trim, plus he sold it like half an hour b4 i got there
another one will come up =D
thanks
fishmonger
