mercury ring compressor tools
green4themoney
Hey guys just wondering a place to buy these ring compressors (in a timely manner) for when i put my 9.8 back together? i practised with my fingers and its almost impossible.
Chinewalker
I've rebuilt many of those blind bore Mercs, never had the compressor tools. I've used popsicle sticks to compress the rings as I slide the piston in. Go slowly, go carefully. Sometimes helps to block up the ends of the crankshaft with wood to keep things aligned while you position things. A sizable catalog of colorful language can be helpful, too.
I put those 9.8 motors together without those compressors.-----I do have those tools for the bigger motors !
green4themoney
I would imagine the inline 4s or 6s would be a necessity. i guess ill try to come up with something lol especially after i did some googling and seen the price of em. just want to make sure it goes in around the seat ok. also i didnt see an ideatification mark on the ring as to which side is "up" so i guess it doesnt matter as well? i think im getting the pistons preloaded with the rings anyways
Ring do not have a top or bottom.-------You must make sure piston ring gaps are where the pins are.----The bore does have a taper that helps getting the pistons in there.
