mercury trim control switch
eastern27
I'm new to this forum, but after reading a few threads I figured someone out there might keep me from breaking something. I have a Mercury single lever control model #88688A26 with a bad trim switch. The owners manual that came with the unit references prying out the bezel to access the switch.
I tried a small screwdriver in the slots, no go. A pair of water pump pliers, no go. Do I just pry and hope it dosn't break? Any tips?
Re: mercury trim control switch
On my MerCriuser, the switch was accessed via two phillips screws on the verticle part of the handle
Ayuh,.....
Can't help you with this Issue,....
But,....
I'm glad to see you got that Other Issue taken care of,......;)
Although you might want to see if your other post in the boating forum can be Deleted.....
