Mercury V6 XR2 - Does this Stator looks bad?
Superjetjim
If your latest idea doesn't pan out, run the motor for a while, anyway you can, to soil the spark plugs. If they are still clean like new, suspect cooling water getting to the spark plugs during running, steam cleaning them, and killing the power in that cylinder.
Thanks Chris.
Latest theory (new coils). Changed things, but didn’t really improve things. It’s bucking when trying to accelerate past 4K RPM’s now, a very defined miss-fire. To rule it out, I’m making a new loom between switch boxes and coils (mine is original and 30yrs old. Could have an intermittent break in the wiring. Whilst I was at this I pulled the exhaust chamber cover. All clear and looked fine. Pistons sides looking really clean and new.
Interesting what you say about the plugs / water getting into cylinders - all 6 of the plugs are really clean and never seems to carbon up… it might also explain where all my cooling water is going (lack of meaningful flow) - at 4K RPM it’s not even registering 5PSI on the water pressure gauge. What pressure would you expect at that RPM? I’ve just ordered a complete OEM water pump kit with new housing and gaskets. I only changed the impeller last time.
Also, where are the likely areas of water intrusion into the cylinders? Heads gasket is one I guess, but any other likely areas?
Dukedog
your pressures aren't gonna change till you address tha holes in tha adapter plate....................
Superjetjim
Hi Dukedog, any ideas what this is, it was spinning round the outside of the water tube that runs up the leg to powerhead. Made of thin aluminium. Looks like it might have been melted and deformed as sat in the flow of exhaust gases below the exhaust defuser. I've connected a hose up the water inlet tube with the leg off and I have no leaks, just cant figure out what this is or where it came from. Nothing showing on the online parts finder schematics.IMG_7642.jpegIMG_7640.jpegIMG_7639.jpeg
Dukedog
not a clue?.. what ever it is it should not have been there...............
tha only thing on tha "outside" of tha tube will be tha plastic guide tube on top of tha pump... it usually gets melted without tha exhaust "can" in place......
Superjetjim
Further update. Installed the new impeller and housing - water cooling is now sorted and running a strong pisser out of head and poppet at idle 👍🏻
This has also been useful as it’s highlighted what I believe is the cause of the primary issue. As soon as I installed the new impeller (and water pressure it up to where it should have been) the cylinders cooling jackets are now full - this is allowing the cylinders to draw in cooling water on the down stroke and putting out the combustion in some of the cylinders. It’s so prevalent that the motor now cuts out on idle, like its mildly hydraulic locking and also won’t run above tick over (it was 4,000RPM last week on low cooling water pressure)
So I’ve pulled the heads and put a straight edge over them and checked them with a feeler gauge - both of the ‘clean pistons / domes’ allow the .003 feeler gauge through easily.
Red crosses show where the feeler slides under.
Also a couple of pics of the cylinder heads and pistons. There’s some visible signs of previous damage (ahead of the rebuild done before I got it) showing witness marks from roller bearings.
Superjetjim
Interesting difference in head colour on the cylinders that might be leaking. Middle one passed the feeler gauge test. Top and bottom don’t.
Every outboard cylinder head I look at is warped !----Just the nature of aluminum castings.----Resurface it and test run.
Superjetjim
Been to the machine shop today, they measured it and laughed. Gave me some guidance on what to do. Got a sheet of glass, bonded a flat big sheet of wet and dry 120 grit and re-decked it, all back in tolerance now. New head gaskets on route.
Superjetjim
They laughed at how clean the top cylinder was and that corresponded with the areas that were way out of tolerance.
