Does anyone know if you can bench test the trigger of a 1978 distributor and how?
D dtillotson Recruit Joined Aug 22, 2010 Messages 2 Aug 24, 2010 #1 Does anyone know if you can bench test the trigger of a 1978 distributor and how?
Faztbullet Supreme Mariner Joined Mar 2, 2008 Messages 15,938 Aug 24, 2010 #2 Re: Merury 1400 Trigger test Yes you need a switchbox and coil. It is easier to test it on the engine. See attached.... http://www.cdielectronics.com/InstallSheet/134-3736.pdf
