Lou C
- Joined
- Nov 10, 2002
- Messages
- 14,065
Re: Milky oil in brand new motor!
Do you see any signs of rust around the riser/manifold joint? If that gasket failed it can let water from the cooling passages down the exhaust gas passage and right into a cylinder. I'd try changing that gasket, check the sealing surfaces very carefully and and crank it over again with the plugs out. See if you still get water. Is #4 the rear cylinder closet to the riser/mani joint?
