Milky white trim fluid in resevior
EricT22
Checking fluids today and i thought the trim resevoir was empty at first glance so i popped the top and it was full but just white milky fluid. Boat is new to me so not sure how long its been like that. Where do i go from here as far a removing the fluid and finding the issue? 88 sea ray stern drive w/4.3 Merc
Most likely a leak at the trim cylinders. With the boat out of the water, operate the trim up and down a bunch of times and look all over the trim cylinders for a leak, particularly at the fittings where the lines connect.
EricT22
Ok I’ll give that a try today. How do I go about getting the old fluid out of the reservoir? Can I use a bleeder pump to just vac it out and add new?
Ayuh,...... That'll work, but may take a few times of suckin' out the nasty, refillin', cyclin', 'n suckin' out the nasty, refillin', 'n cyclin',....
The problem will be purging the lines and the trim cylinders. So you will have to do a bit of fill and purge anyway.
EricT22
So I tested and tested today by raising the trim and lowering and I don’t see any leaks whatsoever. Next step to check?
EricT22
Just to be clear I checked both lines going in on both cylinders and the seals as well
