Minn kota help.
horsefly60
I have a Minn kota. WEAI2729494. I find it is a weedless wedge. Maybe 2008? No sure. I can't find what size thrust it is for the life of me. 65 / 70/80. Trying to order a center lower section. ( Magnet came loose) Thanks guys
My Minn Kota's have a silver plate on the tilt bracket, you may need to tilt the motor up up down to read it. It is on an inside edge of that bracket.
The tag on my MK motor tells everything. 55# thrust and a 55" shaft length along with model and serial no.
Then I went out to my barn and checked my old MK transom mount....yep, 36# thrust and a 36" shaft length along with model and serial no. Called ny neighbor and so does his MK motor show the same thing....has your motor tag been tampered with ??
