misfire on high revs
merc man
ok
where do i start just came back from using my boat and my 40 hp 4 cly mercury has developed a misfire at high revs /under load it's not noticeable at low revs but when you open the throttle it misfires any one out there know wher to start ? many thanks all :blue:
Bosunsmate
Re: misfire on high revs
for stsarters check your plugs.
they might show water intrusion or something else
Texasmark
I was always taught plugs at high rpms.
Mark
merc man
new plugs cleaned carb new fuel still misfire on high revs what about coil packs ? any ideas anyone please
Texasmark
Get a helper and a battery powered timing light like you used to use when you had the old auto ignitions with points and a coil. Get her out and when she starts messing up have your friend get the TL sensor near the plug wires, don't have to touch, just near. If you are dropping a CDI the light will quit firing. Easy and cheap and "dirty". Grin
HTH,
Mark
merc man
HTH,
Mark
Thanks for your help but is there any way i can test the coils ? without cranking over
