Miss/Pinging
James D. Evans
Picked up a 1984, 199 Bowrider, 3.0l Mercruiser, outdrive is mercruiser also, has 3.0L on it. Do not have the engine or outdrive serials. Boat and floor is in really good shape. Almost new looking inside.
Heres the problem, it pings at idle and when underway. The miss started after about 20 min of running. Good volts, Oil pressure is good, temp is good showing about 145-155 on the gauge. WOT about 4300 RPM. Power seemed smooth though acceleration, whether easy or hammered. Not a hesitation when coming up and out of the water. Starts up perfectly fine cold or hot, cold- 2 pumps of the handle and she fires right up. Hot- bump the key. Motor shakes alot when first started, which seems normal according to my research. A little shaky when warmed up, noticed it shoke the boat a little in the water at times idling.
Boat hasn't been run on the water this year at all, started twice on the hose, and was winterized 10/13 (have reciept). Not sure if stabil was used. Oil is crystal clear. Had about 4-6 inches of gas in the tank when I picked it up, and I put about 5 gal of recreation (non Ethanol) gas in it before hitting the water. Smelled like it was running rich, but that could have been from another boat, because while it was idling we were in a high traffic area waiting to get to the ramp.
Could this be caused by the low amount of gas that was left in it for over 6 months? Should I drain it, or add seafoam or another additive(s) and fill it up and run it? Just don't wanna burn the motor down...
stonyloam
Re: Miss/Pinging
Check your timing. As for the gas, I (IMHO) would fill it with non ethanol (89 octane if you can get it) and run a tankful through.
James D. Evans
Re: Miss/Pinging
Checked timing, dead on 6* BTDC. Does advance with throttle. Put new plugs in, and adjusted the mixture. Ran on the hose for about an hour, the weather didn't permit boating last weekend. So, hopefully this weekend I can get her out. Plan to put a bottle of heat and octane booster to help with the few gallons of old fuel in the tank, and top her off with fresh fuel. Maybe put a bottle of seafoam in too. Can you add too many additives?
Since the weather didn't let me get out, I pulled all the wood trim and refinished it. Rewired and installed new lights on the trailer. Replaced the radio with a more feature rich one. Fixed the horn, and buttoned up some loose wiring. Even thought I didn't get to get her out, I still got to spend the day on and around her!
Re: Miss/Pinging
Ayuh,.... The Best favor you can do yerself is to add a canister type fuel filter, 'tween the tank, 'n fuel pump,....
James D. Evans
Re: Miss/Pinging
Canister, like a metal filter found on old cars with nibs on each end for hoses?
Re: Miss/Pinging
Nope,... The spin-on canister type water separatin' kind,...
Found here,....
NHGuy
Re: Miss/Pinging
And don't put any more gas treatment in it. just use up or pump out what's there and get to plain ole gas.
