mixing old with new?
maxxman04
can an 83 merc outdrive, alpha one series, work with an 898 series transom/gimbal? both are from 350 motors, the 898 setup being late 70's/early 80's.
Re: mixing old with new?
Ayuh,.... That'll work...
maxxman04
thanks, greatly appreciated. any idea roughly what year or design will not work with the 898 series? i ask cause the outdrive i got with the 898 setup is corroded, rusty inside. i have a line on the 83 alpha and an 88 or so alpha, both from v8. just curious how interchangable the merc o/d's are. thanks again.
cooter2506
I think if you stay with a gen 1 alpha you will be ok but others may chime in
maxxman04
thanks. hard to track down a good 898 series, so i'm looking into options.
Ayuh,... A Brand New SEI drive,.... Alpha 1 series.... The Gen.IIs are different...
maxxman04
you guys are a wealth of information, and a big help. thanks again. the gen I's are plentiful and affordable, so it seems that is the way to go. thank you again.
