Mixing Power Port and Standard Pistons
Jim662
I am repairing my power head. Had to bore cylinder #1 .015 over. My replacment piston on my 1150 has the big hole in it perpendicular to the wrist pin. I presume this is a power port piston. Can/should it be mixed with 5 standard, non power ported pistons (pistons with no holes in them)?
Thanks.
Jim
Re: Mixing Power Port and Standard Pistons
It should work fine. Since your block is not bored to take advantage of the power piston, it will not function at all.
