more hull painting questions
hdck
I am wondering if I take the paint all the way off down to bare wood can I use bondo to make the hull smooth prior to sanding, cleaning, priming, sanding, cleaning, priming, sanding, cleaning, painting, light sanding, cleaning painting? Thanks for any help
Re: more hull painting questions
Personally,..........<br />I think if the Paint is Still Stuck,.. Why take it Off.............<br /><br />Prep over it.......
flashback
Hey Bondo, you gonna let him use you like that?? :D :D
Originally posted by flashback:<br /> Hey Bondo, you gonna let him use you like that?? :D :D
Ayuh,...... Well,.........<br />Bondo doesn't mind Filling Cracks,................<br /><br />As long as they're of the Female persuasion........................ :D
flashback
See I told ya!! Just don't use bondo below the waterline.. he gets soft and falls out...
:D :D :D :D <br /><br />Ayuh,............... I Hate when that Happens..........
Liquid_force
The funniest part about all the puns is that Bondo's status is "rear admiral".<br /><br /><br />
flashback
Oh Boy, I think i need to get back to work, I spend way too much time here!! :D :D
