more questions identifying parts
robeward
got a couple more items I need to learn about on my new ride.
First pic.
1) Distributor? (p/n 1104060)
2) Coil??? Do you buy separately from the distributor?
3) ????
4) Tilt/Trim relay?? Has Volvo on it. There is a circuit breaker right beside it.
Second pic
Item on the left is tilt/trim pump and reservoir??
What is item on right??
Third pic.
Close up of item on right in second pic.
Thanks.View attachment 229136View attachment 229138View attachment 229139
Re: more questions identifying parts
First pic.
3) ????
Second pic
Third pic.
Ayuh,.... #1 is the distributor,....
#2 is the coil,....
#3 is the oil pressure sendin' unit,....
#4 is a relay, donno what it's for,...
Next picture shows the trim pump,...
Last picture is a trim tab pump,...
robeward
you are on it Bondo. Thanks again. Is the trim tab pump and reservoir one unit?
