motor starts when i dissconnect main engine harness and jump starter
old evin
disconnect harness jump start it fires. connect harness turn key crank crank crank. put in a new ignition switch same thing. any ideas
emdsapmgr
You don't mention the hp or year of your engine...Does your control box have an emergency stop (lanyard) switch?
Sounds like the ign killer wire (usually black/yellow) is grounded somewhere.
