Motor Swap ? volvo v8
robjen1019
I have a 1987 volvo 225, which is a 305 gm. Im wondering if I can take a 1985 marine 350 and replace it. Will the intake, exhaust manifolds, and gimbal housing swap over?
Re: Motor Swap ? volvo v8
Ayuh,... If it's actually an 87, you need an 87 or Later replacement...
The rear main seal changed in 87,+ previous motors don't swap, Easily...
ringmaster72
You will need a pre 87 flywheel. The intake will fit, and I see no reason why the manifolds wont as well.
