Motorguide Props
tysdad2010
Right now I am currently running a beat up (tips broke off) Machete 3 blade prop on my motorguide trolling motor it was like that when I got the boat...I think it is time for me to replace it...So I am trying to decide should I get a new Machete 3 or try another blade? What blade are ya'll useing on your motorguide trolling motors?
I go trough alot of thick pepper grass,hydrilla,lilly pads,all types of grass I need the best prop I can possably get...
Your opinons would really help me decide thanks alot!
Sorry for the bad spelling
Re: Motorguide Props
I'll move this over to the Prop forum for you, maybe that will workout better.
Texasmark
Weedless type props would probably be best suited. Comparing to weedless props on small outboard motors, one would look for blades with a high degree of slope from the butt of the blade out to the tip; the more the better. This will be your least amount of thrust, but you are after getting through the muck; so you can't have it all. It should just roll off the blades.
I have run a long prop on a Minnkota years ago. It was at least 10" long and 2 blade. I doubt that you want that. I didn't like it because it took too much power to get it turning and at low speeds it was not very practical as a result.
I have seen MG props that had 4 little stubby blades. I think this might do you as the short blades would act like a grinder and chew up the goo as you went through it rather than have it get wrapped around the big blades. I know this contradicts what I said initially, but you can follow my thoughts and I am thinking through this as I type.
I think I will go with the 4 short blades. They aren't all that expensive so if you miss it, you haven't lost all that much. Try again with something different.
HTH,
Mark
