Mounting a trolling motor on Bowrider?
Status
Not open for further replies.
BlueNote2
Trolling Motor Bracket? ??
Does anyone know what this bracket is, and where I can get one?
I found this bracket on the forum, but OP did not respond to PM.
This appears to be home made (so to speak). Get an aluminum or stainless steel plate and add to standoffs to secure to the deck. Shouldn't take much
fetch
Edit: I'll add something just noticed, appears the forward most standoff is in line with the side of the bow light. If it is this can be an issue for navigation and seeing the light fully to starboard
BlueNote2
@ AllDodge!
Yeah, I started thinking the same... might be home-made.
Good observation. Def. do not want to cover the lights!
Edit: Yes, a quick search of "Stand offs" revealed a lot of chrome stand-off options. That would be easy and look nice.
I could mount it to a Minn Kota quick-release plate.
@ AllDodge!
Yep, that would look good and do the trick. If you do it make sure to take pics and post, ya know how we all like a good picture show. :D :D
BlueNote2
Trolling Motor Mount on Bow Rider:
(Using Minn Kota Quick Release Plate and Stainless Steel 'Standoffs/Spacers'.)
Here are a few pics of work in progress. I will post pics of finished project when done. "Stand-Offs" cost about $10-12/ea. plus rubber washers, bolts, etc... about $60 total. A little pricey, but a better than a block of wood!
Removed cleat due to space issue (both won't fit). using reinforced cleat backing for first hole). IMG_3064.JPG
Pretty close to level, but it will probably all change when in the water. i can always add or subtract washers. IMG_3069.JPG
That's a nice looking job, and going with stainless is making it standout. :thumb:
BlueNote2
AllDodge,
Thanks again. Glad you pointed me in the right direction! I already had a block of wood cut for the base (and it wasn't pretty either).
This one is not perfect, but it is going to be solid and not terrible looking!
*i plan to use some marine-tex to patch up holes.
BlueNote2
A few pictures of completed Trolling-Motor Mount:
BlueNote2
sold my boat recently, but is there something I can help with?
Captain Thad
BlueNote2
I am doing the same thing u did! And u did an awesome job by the way. I machined 4 stand offs at work that I will cut to size.
1. Can I pm u my questions during my process?
2. What did u use for backer underneath?
3. Approx. how long were your standoffs.
4. Hard to see from pics did your motor rest on the seats?
5. What kind of boat is that?
6. Looks like it would work GREAT! How did it work?
7. Did it need to be mounted so high...off the gunwhale?
9. Where did u put the batteries.
10. Any suggestions to someone who is going to this now...such as myself?
11. Anything u would do differently?
12. How long is your motor shaft?
Thanks
Thad
BlueNote2
sure, no problem. Or, keep it in forum (others trying same thing may appreciate it).
The cleat had a piece of wood glassed-in that the screws ran through and were then bolted. I basically did the same thing.
I used a couple pieces of lumber that I cut down to size and pre-drilled (maybe a quick coat of shellac, varnish, or primer to seal the wood), then ran the bolts and lock nuts through and tightened it down. I don't remember if I used liquid nails or not to secure the wood to the boat, but I don't think so.
3. Approx. how long were your standoffs?
I bought an assortment of sizes of SS Stand-offs from McMaster-Carr (for those that are not able to machine their own). I think they ranged from 1 to 3" I leveled the quick-release platform and then measured the height. Because it was not a flat surface the stand-offs were all different heights, and I compensated with SS washers and fender washers where they touched the boat.
Diagonally so it rested on handrail on opposite side. I included some new pics, but don't have any with motor on, sorry.
Searay BR 19 (Bowrider - 1987)
Thanks! Yes, it worked with no problems. Trolling was perfect, (except I could have used a more powerful motor, boat was heavy) but actually that was ok. I had it at full speed when stowed, and no issues with that either. The head of the motor was tied to the hand rail with a velcro strap when not being used, which kept it pretty snug and did not bounce much.
Yes, when i pulled the trolling motor in to store, it sat flush/level along the gunwale.
9. Where did u put the batteries?
If you look at the picture with the dealt polisher, you can see the corner of the battery box in the photo. That is exactly where is went.
The bowrider has a seating and there is an anchor tucked under the very front. I permanently mounted a Battery Box Strap in front next to anchor storage. In other words it sat just to the right of, and behind, the trolling motor (against the flat edge- seen in picture). I also made a removable platform using carpeted plywood, where I could add/remove the cushions and have a fishing platform or seating. the person fishing in front could reach the motor and battery while sitting.
take your time. Not difficult. I didn't like drilling holes in the boat, so that took the longest time to make absolutely sure it was the correct location.
A few thoughts on location: I wanted it to drop to the water so that it did not hit side of boat, I also had to be careful that it did not interfere with the snap-on cover on my boat, and wanted it to rest against the handrail on the opposite side so that it would travel nicely. As AllDodge mentioned, I also did not want it to interfere with lights in front either. After all of those considerations, there were really only a few places it could actually be located.
no, not really.
I don't remember some of the details. I think it was 48" , because it was a long way to the water.
BlueNote2
No Title
Captain Thad
BlueNote2
As you are sitting in boat...was there any reason u mounted it left to right vice other direction?
Captain Thad
BTW
I am mounting a MINNKOTA POWER DRIVE V2 on a 2004 Bayliner 195 BR.
I am using a MINNKOTA Quick Release Mount MODEL MKA-16-03
Just in case someone else is doing this.
My family loves to boat and I love to fish.
jbcurt00
Capt Thad, please start a topic about your boat and projects you're doing on it.
Captain Thad
BlueNote2
I had to start a new thread.
Here is the title.
Minnkota PowerDrive V2 & a Minnkota MKA-16-03 Quick Release on a 04 Bayliner 195 BR
Status
