MPG on 1/2 ton and 3/4 ton trucks
drrpm
Re: MPG on 1/2 ton and 3/4 ton trucks
I've owned 3 trucks. The First was a 1996 F-150 standard cab with the 4.9l
engine and a 5 speed manual. It had dual tanks and got up to 22 mpg on the highway which gave it a driving range close to 600 miles. Around town it got about 16 mpg. The second was a 2001 F-150 Supercrew 2wd with the 4.6l engine. It got about 14 mpg in town and 18-19 highway. When towing my 20 ft bowrider it got about 12 mpg. My current truck is a 2007 Toyota Tacoma extra cab 2wd with a 4.0l engine and 6 speed manual. I can get 22 mpg on the highway if I keep the speed around 60 mph. It gets 17 mpg around town. It feels like it tows better than the F-150 but I haven't calculated the mileage because its only about 5 miles from where I store the boat to the lake.
204 Escape
Ensign
'01 F-150 Supercrew
4 X 4 Off road package
3:55 gears with limited slip
PS, PB, Air, Auto.
5.4 V-Tow package
OUT OF OVER-DRIVE
Pulling a 3100 # boat, etc., (To the lake) = 9.1-10.5 mpg (This is on a highway, with alot of hills
Coming home, same stuff, = 11.5 + (on a good day). I guess it's because I'm headed down hill, I don't know.
I drive an average of 40-45k/year. Unloaded I can get up to 19 mpg, but realistically, an aerage of 16+
mthieme
Talked to a friend today....he has a 198x Chevy 1/2 ton, 305 auto trans.
He said he gets about 18 mpg hwy and 12 mpg towing (hard towing...lotsa weight going up mountains).
Incorrigible
I'm driving a 2002 Chevrolet Suburban Z71 1/2 ton with the 5.3 liter V8.
I'd say I typically drive pretty hard, and get somewhere around 15-17mpg, including a goodly amount of city driving. Down the highway at around 75mph I'm somewhere up around 18-29 mpg.
Towing either of my boats I obviously back off on the speed a little, and starts are much slower, and still average between 11-13mpg depending on roads conditions (flat or hills, city or highway)
I was considering a 3/4 ton diesel as a tow vehicle and getting a car for the rest of the time. I spoke with a number of people including a few mechanics who thought I was out of my mind. The 3/4 will tow MUCH more, the breaks are better, the transmission is better, basically the whole drivetrain.
Thing is this: They still break, like anything that has moving parts, and when they do, they're expensive to fix. The mechanics recommended that for my needs (I don't tow often, one boat is in a lift, and the other only comes out for a few good trips a year) I'd be better off taking the cost difference in everyday fuel use and repairs, putting it in savings, and replacing anything that breaks.
2 cents worth
crackedglass
Re: MPG on 1/2 ton ans 3/4 ton trucks
thats the thing. Im not really sure. More then likley not. I love my little tinny and the little lady and I have decided we are going to buy a house before I invest in a larger boat.
I guess this is more of a question of how much of a hit in mileage on the daily drive will I take by stepping up to a larger truck. BTW, I have always been a truck guy. as much as I like getting 25+ MPG in a little econo box, im never happy. I love my little Ranger but ALWAYS look at guys driving full size trucks with envy. On the plus side My 2wd ranger does have the suspension and brakes of the 4WD model so In theory mine is built with a few of the better parts.
Like I said, I like the truck I have currently, its the newest truck I have ever owned, its the right color, low miles, it has the 3.0L v6 which I am rather fond of and 4:10 gears so it does have some pep when needed. Im sure fully loaded my boat and trailer still come in under 1000lbs, so tow ability isnt a factor. my main issue is with the cab size, transmission (5 speed on the ramp isnt always fun), lack of 4WD and lack of options.
here is a pic of the truck and boat.
You have plenty of truck for the boat your pulling, why give up something that works for something that will no doubt cost you more money no matter how you go about it?
My Ranger is a 2.3L stick long bed, far less power than your 3.0L and it does fine up to about 1500lbs at the ramp and I've towed much heavier a few times as well.
I too wanted something bigger in order to be able to tow a bigger boat, I drove a new F150, and a new Dodge 1500 last summer, both for a full day, both were demo's with some miles on them. The Ford couldn't break 12mpg running around all day with the air on on two lane roads without a trailer. The Dodge had the "variable displacement" option, which I guess means it drops cylinders when their not needed. It sure did little for mileage, I got only 11 out of that truck for the two days I drove it. It didn't handle or feel as good as the Ford did either.
I have two full size Fords, both have the same motor, trans and rear ratio that the F150 has, both would outrun that F150 I drove on bad day, yet they get consistantly over 21 per gallon? What did Ford do wrong? The truck and car weigh nearly the same, the difference is no more than the weight of a passenger and the extra full tank of fuel in the truck.
I drove a new Chevy 1500, 4.8L V8, a loaded extracab 4x2, for two days, it got consistantly over 20 mpg. This was not a new truck but a buddies well used and abused 2002, I also used it to tow a 24' boat from NY to DE. and got over 18 mpg on the turnpike with that on the back.
It handles like a wet fish though compared to the Ford, but like I said, it's well used.
For now, I pretty much decided to keep my Ranger, I'd buy larger if a 'deal' came along, but it would have to be quite a deal. I also doubt I'd buy new right now, I'm just not that impressed with what's out there in half ton trucks.
I also drove a new Toyota full size Tundra, it wasn't even in the same class as the Ford or Chevy. It was tight to fit in, lacked sustained power, and visibility all around the truck was bad. They also don't offer the same cab, bed and motor options in 4x2 as in 4x4.
A buddy has a Nissan Titan, he's got about 80K on it and got it in '04. He said it's been an ok truck but has had a trans fail, and it gets about 10 mpg towing his 18' jet boat. He's been trying to sell it but no takers. I see those trucks all over pretty cheap lately too.
four winns 214
I have a 2007 Chevy Silverado "Classic" (basically a 2006 body style built for 2007 model year). It is a plain Jane "Work Truck" trim with a 4.8L V-8, automatic transmission with tow/haul mode and 3.23 rear end with locking rear differential. I tow a 21' Four Winns 214 deck boat that weighs 6,000 pounds on a trailer with surge brakes.
I am VERY pleased with the mileage this truck gets. Driving it like I have a lick of sense, I get 18.5 to 20 mpg from around town. "Around town" for me is driving from semi-rural Oldham County, Ky (a bedroom community for Louisville, Ky) 26 miles to work and around Louisville. On an interstate trip, I get 23-25 mpg driving 65 mph. The mileage is as good or better than the 4.3L V6 in my old Chevy S-10.
Towing the boat, I get about 12 mpg. I added a transmission oil cooler to the truck right after I bought it. I also equipped it with one of these:
http://www.scangauge.com/
This little gem is fantastic and well worth the money. My truck doesn't have a transmission oil temp gauge, but it is equipped with the sensor and this gadget reads it. I've never seen my trans oil temp over 185 while towing.
Another neat thing this gadget does is act as a "flight data recorder". It captures max speed and rpm for the current and previous day. My neighbor drove my truck and I saw that he hit 5531 rpm and 81 mph while towing my empty trailer back home after dropping my buddy and me in the river. He won't be doing that again!
I know many purists will dis my truck because it doesn't have a tow package, but it handles the boat just fine and doesn't kill me with the mileage on the 90% of the miles driven without the boat.
I have a scan gauge too. It is the greatest gauge I use. I keep it in my car and when I need to I transfer it to my 4Runner. My older Chev K2500 is a 95 and the scangauge will not work in it. A really great tool to moniter performance.
Shizzy
Ensign
thats kind of what my thoughts over the last few days have been. I have been seeing many vehicles coming in right at or slightly less MPG then what I have. the best I have had with my truck is 23MPG and the worst I have seen was 17MPG with the bed fully loaded pulling my boat that was full of gear with a kayak strapped on top and my large friend in the passenger seat. It really wasnt an issue of "needing" more truck, but wanting more truck. My only real issue with mine is its missing a few options I would like. Im only in just over $5000 with the truck and its paid for. It hasnt let me down once and looks good to boot. Im really thinking since I plan to keep my tinny till it no longer floats, that it would be a good idea to keep the ranger till the wheels fall off. it is a dead simple vehicle and its paid for.
pteal28377
Allright Phill, define those mods . . .
Headers , High Flow cats, dual exhaust mandrel bend, high flow muffler ( all muffler system Gibson good junk), throttle body spacer, k and n cold air intake, Diablo engine programmer and bigger map sensor. All paid under 1800 bucks of course I run a truck ACC shop so parts my cost cheap.
Not to sure about HP but will smoke them pesky Tundras :rolleyes:
Senderofan
ok, I'll jump in.
2001 F250 7.4 Diesel, long bed, and crew cab! My truck is so long it almost takes up 2 time zones.
It get about 17 MPG on the highway. With most trailers and boats, about 13 mpg, and 10-12 with a 5th wheel trailer.
BTW, if you add a chip to the truck, or reprogram it, your MPG gauge that comes with the truck will be off. I suspect this may be where some of the "really good" gas milage comes from with the diesels. However, if you calculate them by hand, it's hard to go wrong.
For several years, diesel has been more expensive than gasoline. This happened within about 6 months of me buying my truck...:)confused: so, what's up with that!?!!)
Not sure what you're talking about the mileage gauge in diesel trucks. Maybe you mean the "DIS" readout....the ones that give you instant mileage or trip mileage. I don't have this type of setup in my diesel....I hand calculate all my mileage. My Quadzilla Stealth and Stealth-R tuners only help the situation...by being able to recalibrate the speedometer / odometer for tire size. I've found the tuner actually helps me get better fuel economy...hand calculated...probably because I don't have to depress the accelerator pedal very far to get moving at a moderatley brisk pace. I also get significant mileage gains when I use my propane injection...along with the tuner.
Wayne
happycamper
'08 Silverado 1/2T 4x4 Ext. Cab 5.3L/3.73
21mpg hiway
16mpg towing 3000# boat
14mpg with slide-in truck camper & towing boat
LOW-LIFE
a turbo diesel is the ONLY way to go. can tow anything you want and while towing double the load will get the same or better fuel miledge as a gasser, when empty will get far better miledge if compared to a vehicle of same size with gasser motor.
JoLin
I'll chime in, too.
1998 Chev. K1500 (4x4) - 1/2 ton
305 (5.0) Vortec
Auto Trans w/OD
3.73 Rear
16" wheels
140K miles
I only tow occasionally and for very short distances, so haven't tracked mileage that way. No matter how I drive it otherwise, I get 12 mpg.
danfrompgh
My 2006 F 150 w the 5.4 towed great,stopped great but killed me at the pump. With or without the trailer it consistently got 12 mpg even after numerous visits to the dealer. Others with the same setup are getting 16-18 city. Mine was a factory turd and I was glad it was a lease so I could give it back. Hope your not the guy who bought it and beleave the 15-19 mpg bs on the window sticker.:rolleyes:
chrisfer
07 Ram 2500, 5.9 Cummins diesel, 6-speed manual
18-20 mpg average hand calculated (not from the display, that lies), towing my 1965 Whaler 16 doesn't seem to change the mileage, maybe puts it toward the low end of that range.
spudshaft
'99 f-150, 5.4 supercab 4X4, 3.73, in town 12.6. With synthetic, 13+
'88 GMC Jimmy, not more than 10
