muddy grease
imraan47
Got some dark brown grease coming out from the back of the wheel on the axel...
is it a bearing or seal broken?
i can see it splater on the rims at the back of the wheell...nothing wrong on the front and its clean where the lugs nuts and that zirk fitting is.
Mi duckdown
Re: muddy grease
Most likley a blown rear seal. Got bearing buddies that you over greased?
Re: muddy grease
Ayuh,.... 'n it ain't Muddy grease,...
It's Rusty grease...
My guess is, it's been leakin' longer than ya thought....
Probably gonna need a set of bearings, 'n races too...
imraan47
Re: muddy grease
meh i dont hear any grinding when i spin the wheel..
also the trailer came like that actually .. i noticed that one side already had spalshes of grease on the back side of the wheel.
i guess i will just monitor it until i hear bad sounds when the wheel is going then just get a new kit and fix everything
MH Hawker
Re: muddy grease
And by the time your hear bad sounds you will be standing beside of the road trying to figgure out WTF your gona do now and ever things is gona cost you a lot of money because you didnt replace 2...6.00 seals, but hey its yours
90stingray
Re: muddy grease
It's called preventative maintenance! That means you change and inspect things before they are broken. Do yourself a favor and pull the hubs off and have a look. Then go buy some new parts and new grease.
