must have add ons
denniston
to start off, I'm really new to boating. I have a 1978 140hp Chrysler, which i guess is pretty much the same way it came of the line. Are there any add ons I should consider...like is it possible to add say a tach, or a heat guage, updated ignition? Or should I just let the old lady do the fine job she's been doing so far?
wraenking
Re: must have add ons
i would go with 2 things for sure<br /><br />tach and the a water pressure gauge!!!!!
Terry H
denniston...I don't know what boat you have that motor on, but you have a real gem there if it's been taken care of properly. There should be a temp sensor with a buzzer or guage...if not you can add one quite easily...also a tachometer is good, mostly to keep an eye on how your motor is running, but also to prop it right you need to know the wot rpms.<br />First things I would do with a new motor like that is to change the waterpump if you don't know when last is was changed...check the lower gear lube for water contamination and metal particles...check the compression and spark plugs to get an idea how good the motor is mechanically...check the spark to insure electronics is operating properly...replace or add a fuel filter, it can be an inline automotive unit placed under the hood if you want...there should be 2 carburators so you can usually tell if one of them is plugged cause she will only run on half power. There isn't much else to do but to visually check all rubber parts and and electrical parts, replace if necessary. If she's been maintained well you could get many more years of faithful service...just a Thought
denniston
Any idea of where and which guage systems to get for my motor, by the way I have this on an 18' Glasstron. With new helm, and redone interior. Hopefully a new paint or gel job this year.
wraenking
personally , i like teleflex, which are available at almost all boat stores.
These might get the attention of fellow boaters.<br /><br /> click <br /><br />Or, how about some curb feelers? :D
