Navico engine interface cable for nema network
Hi, Just was wondering if I can do this for a 2000 Yamaha sx200txrx 2 stroke. I wanted to use my Lawrence 7ti to monitor engine. Thanks
Short answer, you can't.
Yamaha didn't support NMEA 2000 communications until the 2005 model year
Does that go for fuel management as well?
Fuel management is a 3rd party add-on. Requires installation of a paddle wheel sensor in the fuel line.
In theory, you can use any NMEA 2000 compliment sensor, I run a Lowrance paddle wheel speed sensor on my Garmin, but I didn’t dig into the TI documentation to see if the unit is NMEA 2000 compliant.
Compliant being the keyword. Still a number of units that communicate using NMEA hardware using proprietary protocols
