Navigation Lights for Jon Boat
Woffski
Wanted to ask about what others with Jon boats do regarding navigation lights? Always used during the daytime, however, do experience some reduced visibility issues every once in a while. Wanted to know if used, what type, and where to mount on the Jon boat? Thanks.
dwco5051
I have a set of the Attwood clamp on for my 12 foot tinny that I rarely use at night but they are plenty bright and as GA boater says the batteries last forever.
titaniumneck
I'm cheap as hell, I bought two $2 led small flashlights. Put a frosted medicine measure cup on the end of one, then put it on a pvc pipe, stuck that in a hole on back of boat. Other light I boat replacement red/green lens $3.00, hot glued them on flash light. Velcro tape, front of boat. Done. And brighter then most other boats. 😆
ondarvr
For a stern light you can use a cheap solar yard light, just tape it to a length of PVC pipe, or a stick. Some have an on/off switch, they last all night.
WIMUSKY
Boy, you are cheap! :lol: Whatever works..
