need a prop
jsimms724
gentlemen: I have a 17ft fish n ski with merc 115 inline six s/s prop I am realy happy with the set up now that I deleted the big ugly fin off the back 5400 rpm wot 44 mph nice low end power etc. here is my question im pretty sure I need a spare prop nothing fancy or expensive just a spare to keep in the boat that will get me home. that is the only time the spare prop will be used , i will have the original prop repaired or replaced with one just like it, hopefully the spare will spend the next 10 years in a under seat storage bin, with that in mind any ideas? Is there such a thing has a prop designed for limited use with economy being important Thanks in advance
Texasmark
Re: need a prop
Just getting home means something cheap and doesn't necessarily have to be like the current one. Alum, 3 blade, same pitch or up to 4" lower if you watch your rpms at the upper end. Go by a dealer and they might have one or to a prop shop and may have one they repaired. You can get them on here for $100 but as I said might find one for $50. Even if it's dinged up, bent blades excepted, that would work too.
Mark
