need a Suzuki wire diagram for na 125 controller and a key
sk
i need a wiring diagram for a suzuki 1988 dt85 and for a "na 125" controller. Also how do i know which key to buy for the controller? there is over 5 different ones dont want to buy them all
stylesabu
Re: need a Suzuki wire diagram for nc 125 controller and a key
I have the suzuki factory dt75/85 manual i can get you the schmatic, I don't know what a nc 125 contoller is. as far as a key most have some type of code stamped on them so you can match key
sk
i meant "na 125" is written on the outside of the controller. i'll look for the number on it thanks
stylesabu
Re: need a Suzuki wire diagram for na 125 controller and a key
your controller is na 12S, I have same number on mine.is your key a plastic cap with a steel ring around outside?
benkitto
Hi
Any luck with the wiring info etc, i need the same please
thanks
Ben
stylesabu
I posted schematics in another post, let me know if you can find them
sk
could not find the diagram, but i have no key for the controller i was going to wirer it to a switch with the wiring diagram
stylesabu
there is another post here on suzuki motors with pictures
stylesabu
hers pics
