Need a trim switch replacement
actionljackson
My trim switch has gone bad and I can't find a replacement can any one point me in the right direction? It's a mercruiser commander single lever type control with the trim switch for up and down (not push button) in the handle itself pretty common I believe.It also has a trailering switch below the trim switch if that helps.A part number or somewhere to order on would really help I can't find one in Iboats parts.
Thanks for your help.
Leo
Re: Need a trim switch replacement
I feel your pain......
Try great lakes skipper since you are looking for a part of a control lever........ you might be at the mercy of the dealer and it may be the only place :(
