Need advice using fence wood on boat please
Bustedknuckle84
Im trying to move and raise my live bait bucket higher up (right now it sits on the deck). Im trying to use 2x4's (homedepot kind) and have it all cut out and planned.
Should I paint the wood would or something to help prevent rot and mold from being outside? the wood will be below the bait bucket limiting the sun it gets.
Or is there a different route I should take all together?
r.j.dawg
Ensign
Re: Need advice using fence wood on boat please
Please don't use pressure treated wood. If it's regular spruce or pine it will be ok but I would think it should be sealed just like any other wood they use on boats. Fiberglass and epoxy resin.
Bustedknuckle84
Thanks guys for the fast response does Home depot and/or Lowes carry cedar???
sktn77a
Ordinarily, I would say find a suitably-sized plastic base (dollar store, big lots, walmart, etc). But seeing as you've already cut it, just paint it and use it till it rots (pine rots and cedar costs an arm and a leg!) Fiberglass and resin will work, too, but it can be a bit messy if you've never used it before.
etracer68
Ensign
What is "fence wood". Are there fence trees?
matt167
Use cedar. It's naturally water/rot resistant and won't need painting.
Only white cedar. Common Red cedar has a grain that is more open, and is not rot resistant. Only the heartwoods are any kind of rot resistant.
matt167
They do, but only the common red cedar which is not as rot resistant as White cedar. Only the heartwood is, and Lowes and HD only seem to have knotty garbage in the cedar selections.
Oak or Douglas fir are better/ cheaper alternatives
F_R
I saw an absolutely gorgeous reproduction of an old wood boat at a meet yesterday. He used fence wood for the floor boards (spaces between the boards). He did run them through a planer to reduce the thickness and weight and sawed them to a narrower width, and left them unpainted. After all, they are already pressure treated with wood preservative. It looked right at home in that varnished cypress planked boat.
colbyt
Pressure treated wood chemicals are toxic and can react with metal boat parts.
For the OP. Since you already have it I agree with using it as long as you can. A good primer and oil based paint will make it last longer. Be sure to get the cut ends and all ends well covered with paint. The grain acts like a drinking straw and sucks up water. Assemble it using galvanized nails or screws. Deck screws being the best choice. Properly sealed and painted I see 5-7 years of good use in your future.
matt167
I guess it's probably fine for what he is doing. I know it's not well regarded in the boat building world except strip planking canoes and veneers for the color, but Spar varnish or epoxy encapsulating is usually used in both cases.. I know I used Eastern Red 4x4's on my back deck and they are holding up fine. Just as well as the pressure treated pine
MH Hawker
I recently built 3 shelves for mine and I used 3/4 PVC trim board and stainless screws, I am tried of doing stuff over and over.
JimS123
Toobafores.....OMG.
Oiled teak or mahogany stained and spar varnished.
Anything less on a boat would be sacreligious.
