need cam info please..
bigdave438
hi to all....can any one help me out with this camshaft sealed power speed pro cs-1043m? whats its rpm range..and is it worth keeping...i have a 1982 carver santa cruz 2667, , 5400lbs,,,alpha 1 gen1... And a new engine i just installed 350 sbc 5.7 bored.30 over, ,,thunderbolt iv ignition,,,new flat top pistons,,new crank shaft,,,high volume oil pump,,,brass freeze plugs..new hydralic lifters and push rods,,,882 heads with new valves and guides and springs...three angle valve job,,,all rocker studs pined in.......intake manifold is off my old 260 mercruiser,,,and also the 4 barrel rodchester carb....i have the cams spec sheet but it doesnt state any rpm info and no horse power info...ive searched all over and no luck...i even called the manufacturer and they didnt have that info..so that tells me its a discontinued cam....so im reaching out to all the wise gurus here...thank you in advance....also is it worth keeping this cam or getting something better for my application like sum-k1102 from summit racing...
bigdave438
Re: need cam info please..
Ayuh,... Google the cam numbers,... I kinda doubt that knowledge is something on top of anybody's head,...
I done that many times over and got nothing... which is why I'm reaching to members of this forum,, isn't this the reason for this forum..the reason I need this info on this cam cause my engine wont go pass 3100 rpm wot...
Ayuh,... Is the fuel system givin' good flow, 'n pressure, with Clean fuel,..??
Is the Ignition in time, 'n advancin',..??
Googlin' "sealed power speed pro cs-1043m",...
Brings this as the 2nd link, 'bout 1/4 way down the page is the spec sheet for that cam,...
bigdave438
I down loaded the spec sheet and it doesn't state rpm range...and no I didn't set advance timing...I thought thunderbolt iv didn't need advance timing set...am I wrong?
Ayuh,... Ya set it at idle, but Test to see it's advancin',...
T-bolt IV is a Great system, but even Great stuff goes bad,...
bigdave438
What should it advance to 24 degrees or 27
bigdave438
Part Number:CS1043M
Camshafts
Cam Lift / Intake: .267" Cam Lift / Exhaust: .273"
Valve Lift / Intake: .400" Valve Lift / Exhaust: .410"
Valve Lash Int.:HYD Valve Lash Exhaust: HYD Cam Type: FH
Lobe Intake Centerline: 108 Lobe Exhaust Centerline :112 Separation Angle: 110
LOBE CENTERS R.R = 1.5 I.O (BTC) I.C. (ABC) E.O. (BBC) E.C. (ATC) DURATION INT EXH OVER LAP INT. (deg) 108 SAE J604D 19 78 65 39 269 284 58 EXH. (deg) 112 .050 CAM LIFT -7 29 37 -4 202 213 -11
Notes:STANDARD ROTATION MARINE CHAIN DRIVE
Notes: this is the cam I have in my engine,, is this cam good for my application?
Ayuh,... I'm more concerned that advances, rather than to where,...
It should be all in by 3200 rpms I believe,... I'd have to drag out a manual to be Sure,...
Tail_Gunner
If i were to tell you to get vortec heads and a new manifold your response would be?????...and a 4 bl carb.. Actually a comp cam xm262 would be good cam
bigdave438
Hi sorry I was out trying to figure this out...I ran my boat again full throttle and all of 3200 rpm for a whopping 14 Knotts trimmed out...the boat gets on plan around 1800 rpm full gas tank 105 gallons and 40 gallon fresh water tank in the bow... and a friend 300 plus bounds sitting in the engine compartment playing with the distributor. . And no difference in rpms..so tomorrow im gonna take out the filter from the quadrajet and also change my fuel water seperator...I'm also installing a fuel pressure gauge...
bigdave438
My response would be "IM ALL IN" its a great boat and I have no problem investing money in my baby...I take great care of her and it's in brand new condition....
bigdave438
Has anyone taken a look at the cam spec sheet in post #10...is this cam worth keeping in there...I'm beginning to believe the cam isn't strong enough to push my boat. .if tomorrow by changing the carb filter and water separator doesn't change anything I guess the cam and intake manifold and water pump are outta there. ..cause I cant figure this out... I also tested the compression again and each cylinder has 175 psi..I have now intake manifold leaks I checked that by spraying carb cleaner..I also checked to make sure im firing on the compression stroke tdc...
Ayuh,... That alone will cause a Lean condition,...
bigdave438
Sorry typo. ..I have NO intake manifold leaks...im gonna check fuel pressure today and change carb fuel filter and fuel water seperator
